I have just acquired a toyota SDK8 with a snow bucket and a material bucket. The machine is now set up so the snow bucket will lay flat on the ground. The material bucket is about 3-4 inches off the ground when the bucket bottom is parallel to the ground. I would have to grind off the stops on the machine for the bucket arms to come down further so the material bucket lays flat. Is there a solution that I am not seeing? It would seem that I would need to cut off the welds ...and raise/lower that on the bucket so both buckets have the same distance from the attaching point to the ground. thoughts??
