I recently bought a 2007 463. I was wondering what is the best way to modify the seatbar? I am rather large (275 lbs) and bringing the seatbar up and down is a squeeze on the protective covering of my rock hard abs! I have also noticed that the corner of the bar has rubbed and worn the insulation off some of the wiring harness in the top left corner of the cab. Would I be better trying to increase the bend near the bottom of the bar, or should I cut out a short section of the bar and weld it back together? Hopefully someone has had to do this before. I can't be the only fat guy with a little bobcat.
