Hunterdog967
- Joined
- Sep 29, 2019
- Messages
- 7
Hi i am having a problem with a s185 hydraulic lock not releasing ,machine will start and drive but the hydraulic lock that is electrically released doesn't unlock ,any ideas .
There is a electrically controlled hydraulic lock in the main control valve for the hydraulics that is Not releasing just wondered if anyone had a schematic or has run into this issue like I said the parking brake will release and it will drive but the Hydraulics are locked so pocket won't go up and down and tiltNot quite sure what is not releasing. If it will drive, the parking brake solenoid must be releasing. Lift and tilt not releasing? ---Bobbie-G
There is a 185 turbo book in the manual thread, the schematics should be the same for the hydraulic circuitry.There is a electrically controlled hydraulic lock in the main control valve for the hydraulics that is Not releasing just wondered if anyone had a schematic or has run into this issue like I said the parking brake will release and it will drive but the Hydraulics are locked so pocket won't go up and down and tilt
