Replacement of pin in control arms
Stephend
how hard is it replace the pin in control arms? Can you just buy pins and replace the old one or is there a sleeve that needs to be replaced as well? If there a sleeve can it be honed out and an over sized pin the installed? HOw can you tell if the pins need to be replaced at all?
I am guessing the boom to bobtach pivot pins on a 7 series loader : as what you call the controll arms and what machine your talking about , got a good fix for the a taper pin if thats what you looking for
Whats the fix? mine are worn some and could use some work too....Jeff
The bobtach pivot pins which have the a-taper end that fits into the end of the boom has a tendency to wobble out from the bolt which holds the pin in being loose , this will oblong(egg shape ) the hole the a-taper seats in , once this happens it is hard to kept the pin tight and it just keeps getting worse and worse , there is a bushing to fix this problem , easist way to install it is a magnet drill press , but can be done with a large drill , you drill the a-taper hole out so the new bushing can be placed in the hole , after assembling the bobtach and pins you weld the bushing in and the a-taper is back to OEM specs , Construction Tool Parts has the bushings , pins , etc ------if the weldment that holds the bobtach pin bushing in the bobtach has woddled out the hole there too much for a new bushing to hold in it , you can buy the weldment and cut , then weld the bushing holder in bring that bushing back to new
