PLEASE HELP.. NEED WHEEL BEARING AND SEAL NUMBERS FOR A 1845 CASE UNILOADER
dferrera777
PLEASE, DOES ANYONE HAVE A SET OF CASE 1845 WHEEL BEARINGS AND SEALS THAT YOU COULD GIVE ME THE NUMBERS OFF THE BEARINGS THEMSELVES AND THE SEAL NUMBERS.. TRYING TO GET THEM FROM A BEARING HOUSE (BEFORE I PULL IT ALL APART) .. NOT LOOKING FOR THE DEALER NUMBERS, LOOKING FOR THE ACTUAL NUMBERS ON THE BEARINGS CONES AND SEALS.. thanks soooo much I HAVE A SEAL NUMBER OF CR 24982 BUT NOT SURE IF THAT IS RIGHT FOR THE SEALS THANKS AGAIN, DAVE FERR [email protected] OR 818 293 5345
honestly,nobody has a set of these on a shelf that they could read me the numbers.. come on guys please..
Its not something someone would have on the shelf to look at. Generally if they went and bought them from the dealer, they just go straight into service, no looking at numbers.
You may just have to bite the bullet and remove them and get them from a bearing supply place when you have them in your hand. They should be standard sizes, so a bearing shop shouldn't have any problems getting them for you.
I know you want it so its pulled out and put back in straight away, but not always possible.
This might be to late for you, but if you are able to get the case part numbers sometimes part houses can cross reference OEM numbers. NAPA recently did this for my 430. Saved me a couple of bucks.
