Orifice Tube to slow converted snow plow
kroog
I had to slow the hydraulic angle cylinders on the snow plow I converted from pick up to skid steer. The pick up hydraulics run 4-6gpm. My skid steer runs 20.5gpm. So I made an orifice from a brass pipe plug with a hole drilled in it. Here is a video on you tube. https://www.youtube.com/watch?v=NJtgN6r15Q4
jerry
you should list the bit size you used to get the reduce flow
3/16 ,1/4 etc... ????
good job on the brass works out good .
Jess
I made mine a disk just put into the fitting before attaching the coupler. Mine work good at 3/32 inch diameter.
