Ok, so i have been lazy for the last 10 or so years. I got a machine that had a small engine bay fire and the pump/engine were removed by the previous owner.
FINALLY the day/week/months have come to actually get it going again.
Sadly i didn't take as many pictures of current progress as i should have. I had the chain case hung up by my S250 so i could blas it with a pressure washer. The tag line was going to be, how do you wash your skid steer? but sadly the picture was not taken, oh well.
Back to the build, as the engine/pump was was out when i got it, the pump ports were not plugged up. I didn't notice this till it was home and i could see brown fuzz inside the fittings, after opening it up, the rotating groups were toast. I have pictures of the pump that i will dig out too.
Now, for current progress:
Removing tube lines
Cab and chassis off, leaving bare chain case.
Chassis and arms off
Bobtach with new bosses welded in. I line bored the pivot point for the tilt ram years ago.
Draining chain case, trying to keep some crud out
Cleaned with wire wheel, new axle seals and drive motor carrier seals in. Sorry i didn't get pictures of removing the hubs or seals. I use a bottle jack behind the hub, twist the bolt out a few turns and hit the bolt head to crack the seal. It can take a bit of work, but they will go. To remove seals, drill a hole in the outer part of the seal, as close to the side as you can and use a self tapping screw. Use pliers to pull the seals out. Installing them, i actually made a tool years ago that you put the seal on the axle and use the bolt for the hub to pull the seal in nice and square. Took minutes to grease up the new seals and pull them into place.
Hubs on and tightened to some insane torque (of course to spec that a 6' pipe gives) and primed.
I did paint it black and the bobtach on Saturday, i don't have pictures yet. You know how it goes, you get busy and can't be bothered with taking pictures.
More updates as thngs progress. If you look up a direct link, you can see these images in photobucket: http://s903.photobucket.com/user/tazza_/library/Bobcat 763 rebuild
Removing tube lines
