Tazza: Thanks. That was my suspicion, but I did not know if a hoe had any special remotes/gizmos to allow its use. jI would be surprised if it didn't! Even with seat sensors you need to be able to get flow when not in the machine when you use an excavator attachment. For bobcat machines you either lock the controls in detent or use a switch on the steering lever for continuous flow, i am pretty sure your JD will have this feature too. The seat and seat bar switch will generally only lock out the lift arms and lock the brake, not the hydraulic flow.
Every hoe i have seen just has continuous oil flow, no electrics are needed to hook back to the loader.. YET but i'm sure in time they will find something they want to tap into the machine, they love their electronics.Tazza: Thanks. That was my suspicion, but I did not know if a hoe had any special remotes/gizmos to allow its use. j
