Gehl 4625 won't shut off
Gene
We have an older 4625 which has been a good unit till now. When I last used it and went to turn the key off--it would not shut off. We idled it way down and forced it to quit but trying to move forward and using the hydraulics at the same time. I am thinking it may be the switch but do not know. I restarted it a day later and had a devil of a time getting it started. I had to hand pump the fuel for a long time. Also the hydraulics wouldn't "unlock" when I restarted it and the throttle did not seem to cause the engine to increase R.P.M. Anyone have trouble shooting ideas?
Administrator
Admin
I suspect it has a diesel engine?
Is it electric shut down or a manual cable? if its electric which i suspect it is, you may want to check the solenoid is not sticky.
G
Gene
Thanks--do you know if I could buy a new solonoid at an auto parts store or do I have to order one from a Gehl dealer?
Administrator
Admin
You can get aftermarket solenoids, you will jest need to hunt around a little.
