Fuel injectors
tjc
I just put new fuel injectors in my 743 bobcat they are leaking from what appears to be the nut locking the injector tubes has anyone else had this problem and what did you do to fix it? Do I resear the top of the injector or pull the entire injector and reseat the entire thing
Are you talking about the tube lines from the pump to the injectors? if so, i have found tweaking the angle of the lines fixed mine. Make sure the top of the line seats into the injector nicely before you put the nut on. Not just use the nut to pull the tube line into place.
