easy one - bobtach lever not lining up
azlan58
this is probably a common problem: when i am switching attachments my one locking lever on the bobtach will not line up the the attachments guide holes, i find myself putting a piece of rod dohn the bobtach holes to rock the pin over so the lever will slide down and make its way through the tach and attachment plate to secure it? i see there is a spring/bolt in their, what is the most common problem that causes this Thanks in advance Ryan
Administrator
Admin
It depends on the model of machine, my 731 and 743 machines use nylon guides that can wear or fall out causing the pin to not line up. Could it be that simple for you?
