Default Vertical vs radius lift? Which is better? I'm looking at track loaders and skid steers. Bobcat has equipment with both radius lift (single pivot for lift arms) and vertical lift with a complex linkage. What is your opinion of the two, which is better? I listed the (A) advantages and (D) disadvantages of the two designs that I could think of. What did I miss? Any other ideas? Radius lift: A Lower initial cost, A easier maintenance, A less slop initially due to fewer pin connections, A less slop in linkage with wear, D does not lift vertical, so precise hole boring involves front back movement of the machine. D lower lift capacity because lift moves further outward. D less lift height. Vertical lift A greater lift capacity, A greater lift height, A vertical lift path, D more expensive, D more maintenance, D more slop due to more pins. I guess my biggest concern would be the slop in pins. Is that a real concern? JRP
