coupler size?
jvchap
Sorry for this trivial question...but I'm looking for the size and/or part # for the coupler that connects to the smaller of the two male "nipples" on the front auxiliary block on the Bobcat A300...I need to have a hose made to send the excess flow from a diverter valve I'm using with a Skidril HD-20 rock drill....Thank you very much.
Bandit1047
Are you talking about the high flow case drain? this is the smallest of the three on the high flow side. They are normally 1/2 inch. There should be a number stamped into the male. call a Parker dealer and they should cross referance it for you. Most flat face couplers are compatable.
