Cat 236B
Brad in Wisconsin
My friends skid-steer wants to turn around as it is starting, once running, you can get control of it. He replaced the joy stick...Any Ideas??
He will need to adjust his neutral on the drive pumps. It is not an un-common issue, there will be something on the pump to adjust. I have never done one, but hopefully won't be too hard.
You jack the machine up so the wheels can rotate till you get it right. This way it doesn't drive around on you.
jklingel
Brad: Other than this, how does your friend like his machine? It is on my list of possible machines.
knogen
Take to dealer.pump has problem.not simple. Pilot system. Interlock should not let it move Pump is stuck stroked
