That's the gas engine isn't it? Others have replaced the pump with a off the shelf electric from auto parts store, usually less than $50.Sure it is a fuel pump and not the pick up in the tank? Very common those rot and fall off.
You could run the line to a container of gas to see if it will run then and also then you could check the output pressure. Most old vacuum gauges also do fuel pump pressure.That's the gas engine isn't it? Others have replaced the pump with a off the shelf electric from auto parts store, usually less than $50.
I agree , I feel the original pickup hose in tank should be replaced with steel pipe , such as brakeline pipe . With a proper pipe bending tool you could get as close to gas pump as you wish ., just save room for a fuel filter of your choice. I don't believe I'm the only one driving 40 year old machinery .Sure it is a fuel pump and not the pick up in the tank? Very common those rot and fall off.
