Removing the blower housing is not that easy, if you can leave it in place!. The oil cooler does need to go. Also you need to get to bolts under where the rad sits rite up the back, with everything still in the machine its a nightmare, do your self a favour, leave it alone . With the engine out you may want to give the rad and oil cooler a good clean with a pressure washer and de-greaser.Thanks for all yours reply, they are very useful
I have order a new seal to the pump (I can't feel any wobble in the shaft so I hope it can do it with a new seal), as you now, it can be replaced from outside the pump.
When I ordered the seal, I ask the bobcat service guy how to get the spline off, and he use to heat it up a little and pull it off with a puller.
I will get to it this weekend, if I get the new seal, and after a have clean it up (goos I looking forward to that cleaning jobJ) I don't now if I will take the plastic blower house off, I have to pull out the oil cooler if I do so.
I don't replace the blower wheel now……it cost about 1100 US$…..hmmm, I will try to get a used one.
But else have I received the service and parts manual, and its worth all the money, it cover all the machine very very good include ex. the hydraulic pump and hydrostatic, I can only recommend the to manuals.
/Mogens
When you install the seal you should use a gasket sealant on the outside of the seal just to be sure it doesn't leak between the seal body and the housing. Make sure the seal goes in the rite way!!! but i'm sure you know this already. Good luck with it and do let us know how you go.
