My 444 has a Wisconsin 2 cylinder TFD engine. The governor weight broke off and damaged the housing. Still looking to see what other damage has been done and if this engine is fixable. If I knew what was involve with the taking off the variable speed drive sheave, I would do so and replace the engine with a Wisconsin TJD. Would like to know what size the crank shaft & key way are so that I can keep my eye out for a replacement engine. If there is an expert on removing the variable speed I could use your help. I have already been advised that it can bee damaged easily so I would like to avoid this if possible. Thanks..Joe
