Bobcat 310 Electric Clutches
dnohr
Hi, All of a sudden I lost power in my Bobcat. Checking it out, it looks like the low speed clutch decided to quite working. The engine's running, but the belts aren't turning. If I hit the button for high speed, everything works fine, but I can't really do much work in high. Is there a way to test the clutch to know for sure if it's busted or not? I checked the two wires going to it, and it appears to be getting power (12V) and the ground is indeed grounded. I'm not sure what else to check. I checked for continuity through the clutch, there was non, but I'm not sure there should be. Any troubleshooting ideas?? Thanks!!
