I recently attached a rake with a grapple to my 1993 L555 deluxe. The cable that operates the valve was shot so I replace that with a new one. Replacing the cable was difficult due to differences in mounting the new cable into the holder near the valve. It didn't fit great but I finally got it done. I used the machine for a bit and it was very obvious that I needed to slow down the grapple. Also the cable didn't work very smoothly at all -- or maybe it was the aux valve that didn't operate smoothly. I purchased a flow restricting fitting and placed it in line to the grapple cylinder. That slowed things down nicely but the cable was very difficult to move and wanted to stick in both directions. Within just a few strokes the aux valve seized up. I assumed it was the cable but when I removed the cable the valve remained stuck in an open position. It is affecting the drive and also won't allow the bucket tilt cylinder to retract. The up and down movement of the boom seems normal. Does anyone have some tips on how to get the aux valve to close, or unstick? It seems strange that it worked better (althoug stiff) when I first hooked it up even thought the aux hydraulics hadn't been used in years. Then after an hour or so of use it locked up. Thanks
