Ken, I use shell-rotella in my sports car, It DID have extra lubricating agents including extra zinc. If I remember correctly, shell changed/reduced some of these lubricating?.You want to use a engine oil, 10/30 or 5/30 if your in a cold climate. Regular hydraulic oils, regardless of weight do not have the lubrication that the hydrostatic drive needs.
I'm not aware of a electric over hydraulic system on the steering. If they made one I'm not familiar with it.
My 853 has morse cables connected directly to the hydrostat, about the only adjustments is 1 to be certain you get full speed forward and reverse on either side.
2 that both sides return to neutral when you let go of the sticks.
My machine has a slight lag in responce, you push the stick to point “x” and 1/2 a second later the wheels react to the movement of the steering stick. This combined with the very low effort required to move the sticks makes doing fine movements a bit of a pain.
As far as I know that is the way they are, perhaps the other 853 guys can chime in here.
I do know that my 553 and 773 are easier to get used to
We run there rotella t in all our engines, weight depends on season, expected # of cold starts etc. Not sure what they may have changed over the years.Ken, I use shell-rotella in my sports car, It DID have extra lubricating agents including extra zinc. If I remember correctly, shell changed/reduced some of these lubricating?.
What brand of 10/30 do you use?.
Thanks,
Perry
The reservoir is the same for both the hydralics (loader up down and tilt) and the hydrostats. They share the same oil. 10/30 is recommended for the chain case that runs from the hydro motors to th axels as well.My queston was about the hydraulics for the loader. I know that they use servos on the 853 to make it easyer to operate. I was wanting to know it these can be adjuster or done away with I mostly use this machine for a fork lift and the foot controls are to touchey.And while I asking questions if its good to use engine oil for the hYdrastat drive then it must be ok for the other hydralic pumps for the lift . Not to be hard headed but what is hydraulic oil for.This is my first skeed steer & I dont know much about them. thanks for your help I appreciate it.
Hydraulic oil is made for hydraulic systems, not hydrostatic systems like skid steers use. In a *standard* hydraulic system there is a gear or vane pump that has limited moving parts and low viscosity oil works well. However, hydrostatic or piston pump systems have lots of moving parts that require heavier oil to keep them lubricated or failure can and will occur. I think heat may pay a large part in this too.The reservoir is the same for both the hydralics (loader up down and tilt) and the hydrostats. They share the same oil. 10/30 is recommended for the chain case that runs from the hydro motors to th axels as well.
Only the fan drive uses 80/90 gear oil in the angle drive aluminum gear case just below the blower.
They only thing I can recommend on the foot pedals is try lubricating all the pivot point to reduce any friction. The pedals on my 853 are actually quite smooth. It the best out of all my loaders. The steering however does not lend itself to fine work.
I'm not sure if the other 853 guys experience this or not.
Thanks a lot up to now I wasn't sure about the hyd. oil now I understand now & I'll be adding 10w30 oil to my reservor its been a little low for a while. thanks skidsteer & tazza . Can you address the servo question on the lift system I guess these are not adjustable thanks for your help Mike--Hydraulic oil is made for hydraulic systems, not hydrostatic systems like skid steers use. In a *standard* hydraulic system there is a gear or vane pump that has limited moving parts and low viscosity oil works well. However, hydrostatic or piston pump systems have lots of moving parts that require heavier oil to keep them lubricated or failure can and will occur. I think heat may pay a large part in this too.
When i got my first bobcat i thought the oil couldn't be rite, it was using engine oil!!! but a quick call to bobcat and they confirmed that it MUST run heavier oil like 10w30 for the hydrostatics. They said to never ever use hydraulic oil as it will damage the pumps.
Sorry, i don't own a late model machine, this is one for ken.Thanks a lot up to now I wasn't sure about the hyd. oil now I understand now & I'll be adding 10w30 oil to my reservor its been a little low for a while. thanks skidsteer & tazza . Can you address the servo question on the lift system I guess these are not adjustable thanks for your help Mike--
The only electrical assist i know about is on AHC or ACS Machines if this is what you have you can calibrate the handles if this does not work use foot controls (or fit them).Early 853 had a very sensitive assist Hydraulic for the drive only.Sorry, i don't own a late model machine, this is one for ken.
I have never seen anything in the manual about adjusting the lag, or lack of feed back from the steering. That is what your refering to? as the foot pedals on my loader are as nice to use as any other bobcat I have run.The only electrical assist i know about is on AHC or ACS Machines if this is what you have you can calibrate the handles if this does not work use foot controls (or fit them).Early 853 had a very sensitive assist Hydraulic for the drive only.
