I'm sure this is not what you expected, but this what I finally settled on. http://smile.amazon.com/Ullman-Devices-RT-48LT-Rotating-Magnetic/dp/B0061XFPPA/ref=sr_1_1?s=automotive&ie=UTF8&qid=1421544397&sr=1-1&keywords=Ullman+Devices+RT-48LT Ullman Devices RT-48LT Rotating LED Magnetic Work Light. I started off putting LED worklights on my little Case, and they worked great for a few hours. They burned out, and I replaced them. The replacements burned out, too. It turns out that LEDs don't light the power made by a magneto system, since my Case did not have an alternator. I could have wired them directly to the battery, but I didn't. I then hooked up a halogen magnetic light that plugged into a cigarette light receptacle I installed, but the plug was prone to damage. So I settled on the Ullman magnetic worklights. Since they pull off, I store them inside, out of the weather. They are very bright. I use rechargeable double batteries around the house, so I never have to worry about running out. Plus, I can use the lights for other things if need be. It has turned out to be the ideal solution.
