I'm interested in adding a cab heater to my Case Skid loader. The only room I have is in the rear of the cab mounted from the cab ceiling. My question is when you run the water lines from the engine to the heater what is likely to happen? Will adding coolant in the system from below at the coolant reservoir bottle or radiator work? You need to force it up to the heater unit and would think there would be back pressure. There are factory heaters / AC in this same cab location of the XT's - not sure how they do this? Any suggestions welcomed. Thanks
