The panel under the cab comes out pretty good easy. Doing any major work under the cab uselly means that's the first thing you pull out. The seat bolts to the bottom of the cab.Usually, that part attaches to the cab. If you undo the 2 bolts just inside the cab door opening on either side, you should be able to flip up the cab, and see what it bolts to.
HTH - SR
