Re-installing the engine is indeed a 2 person job.Looks awlful GOOD to me Tazza! I really like the pump color. I've never pulled an engine yet and am wondering how hard it is to connect the drive coupling back up to the pumps as the engine is going back in. Not much room in the back to guide it back together as it goes in I "assume". Wondering if it takes two people, one up front and the other in the back.
And by the way, it looks like the html button you told me about does the trick for paragraphs! Thanks.
One person stays at the back with bars to jiggle the engine forward SLOWLY. You lay down over they hydro pump, put your arm through to the back to the pump and get the person to slowly push it forward to engage the drive coupling. You may need to rotate the engine a small amount to get them to line up. Its really not a fun job but its needed. I haven't attached the stuff to the pump that centres it so i hope it will give me a little more room. I have done this a few times, it gets easier the more times you do it.
One hint to remove the engine, get 2 milk crates and lay a sheet of 1/4" steel over the top, sit it at the back of the machine and slide it out, the milk crates are just about the rite height. If you have a chain block you can lift it out that way too, i have an air powered one that makes it so much easier.
When re-installing it, make sure you grease the universal joint and grease the spline on the pump.
As for the pump colour, that was some paint i got for another project, its not the same as the origional but i don't care, its blue.
If there is anything you need to know about installing the engine in more detail just let me know.
