Well, the chaincase is back together. I managed to paint it today, the weather held long enough to get it all done. Here is a pic.ALL the seals inside my control block are black....
There are 2 quad rings on each spool which my seal shop didn't have the same width, but we both agreed that using a backup ring on the non pressure side would take up the rest, all the other seals are standard O rings and backup rings of a standard size. I will however need to buy genuine boots that cover the exposed part of the spool.
http://users.tpg.com.au/tazza_/bobcat/121_2112.JPG
You will notice on the supports for the axle housings there is pitting all over them and the side of the chain case, there was a heap of flakey rust on here. I think it was from mud that had been sitting on there, both front supports have the same problem. I did remove as much rust as i could with a buffing wheel and a scabbler, i then put rust converter on. I put a really thick coat on these parts to hopefully prevent it from getting worse. It hase all been done in 2 pack paint which should give me a nice tough coat. It looks awfully white! but when together it will not last long, it will soon be all brown and grubby looking.
