So after breaking down each part of the fuel system and determining there was no fuel to the injectors, I finally tackled the fuel solenoid after suggestions this could be the culprit for lack of fuel to the injectors. Pulled the solenoid and sure enough, it fired right up! I want to thank everyone for their input, without it, I'd be spending a few bills on a mobile mechanic. Thanks All!!So I've ruled out fuel lines from the tank to the primer. Primer to the fuel pump. Fuel pump to the filter. The last line I get fuel flow is on the outbound side of the filter. This line connects to a hard line to the fuel injectors. Disconnected each line on the injectors with no fuel confirmation when trying to start. No pulse of fuel coming out. Reading back through some of the advice about the fuel shutoff solenoid being a possible culprit. Some folks have recommended bypassing the solenoid to verify this as the issue. The problem I'm having with that, is I can't visibly locate anything that looks like the described solenoid or pictures I've looked at on my machine. Below my alternator and above my linkage on the right side I have a square relay or some sort that has 2 wires with verified power. I've unscrewed it and removed it and it has a 3 prong plug that it disconnects from. This might be a little easier if I could attach a photo or two for some confirmation.
