I have a friend with a 873g that is acting dead. When you turn the key the only thing that happens is input comes up on screen and a clicking noise from below which sounds like a relay or solenoid and reacts when you raise or lower seat bar. I started at battery and worked my way to panels in cab and can't find any problems with wiring or connectors. I've removed all fuses and relays and cleaned. I called the local bobcat and only thing they would tell me is ignition was bad. Tried to switch two panels in cab from a working machine with same results. Removed and clean connectors on computer behind panel by left leg. Grounds and fuse in engine area looks good and I can turn engine over at starter but shutoff isn't releasing so engine won't start. A/C fan will come on and lights as well. I don't have any manuals except the little one wired to inside cab and it doesn't tell very much. Can't get it to give any codes only "input". I'm running out of ideas.
