I have a 2001 873G. It has about 2300 hours on it and has run really well since I changed the drive chains a few years ago with help from here. I have never loaned it out until this summer. All fluids were filled up when it left and when it came back. It has now developed several issues. I don't know if they are related or not so I will give a summary of what it is doing and you guys can guide me through what to look at first. It has heat/air but it never really has worked...don't think that has anything to do with the new events. I was working last week and it was running fine and all of the sudden it lost power. Doesn't really sound like a diesel. I could have it at full throttle and talk to you if you were 10 feet in front of me. The rpm's go up, but it doesn't have any snort to it. I turned it off. Ordered new fuel filter and all new air filters. Replaced all of that, filled it up with new fuel, same thing. However, it would not start so I took the battery out and charged it (new last year). Still didn't really want to start but did that time. Now it will not start unless I jump it and then it starts right up. At one time, it flashed a message something about a sensor or relay...I believe it was a "starting" sensor but could be wrong. This has not happened again, but I do have to jump it to get it started. I decided to run it for 15 or 20 minutes to see if it would get full power after a few minutes. After about 20 minutes, it flashed a message about coolant temperature was too high and it was shutting down. I let it cool down for an hour, jumped it, drove up the hill and parked. Tonight I was going to take off the fuel line and check the screen at the pick up tube but couldn't get my arm in there far enough. But I did notice that a hose was broken. It is the coolant drive fan belt. Could this broken belt be causing all of the problems? Or just the overheating one? Any advice? I am afraid that I have an electrical problem (no starting), an overheating problem (probably the belt), but have no idea about the loss of power. Keith
