863 HP1
Fishfiles
I'd bet you have 10w30 motor oil in the hydraulic tank , as I have found that is the problem most of the time the HP codes start flying , if so I would change the oil to regular hydraulic oil which is thinner , is it cold where you are at s that seems to add to the problem , if that doesn't stop the code I would change the sensor next
