So I have watched several videos on youtube. I have done several different cars timing belt changes over the years. Just looking for correct procedure on tension. I contacted Dayco and they recommend 22 - 23 ft lbs of tension. So far they haven't contacted me back on how or where to measure that. They said no need for a fancy tension tool. I thought maybe they meant put 22 ft lbs of tension on the pulley as you tighten the belt.(sounds like way to much to me on tensioner pulley) I know about the Deutz tool 3.5 roll her over and the 6.5 - 9.5 readings. I have seen videos where an engine company runs the OTC gauge all the way up to the green.(too tight?) The OTC gauge goes from 30 to 180 lbs. Are these foot lbs? Gonna be hard to measure 22 - 23 when it starts at 30. On this forum in the Gehl section I found the same 22 - 23 ft lbs recommendation from Daycon on this same belt. But then he said they told him to rotate engine and reset it 47 - 68 lbs. This guy was saying that he thought the 3.5 on the Deutz gauge was newton meters and that he converted that and it came out to match the 22 -23 ft lbs. Which I think is completely wrong.(the nm to ft lbs conversion) I have already bought the belt and pulley from bobcat, and the pins to lock cam and crank from amazon. I also supposedly have the OTC gauge on the way from amazon. May cancel it if it doesn't ship soon. Any and all info will be appreciated. This 863 runs good has 3600 hours but I know it probably has original belt on it.
