Farmboy
I would bet your safety valve has been bypassed by puting power to the coil. You don't have to push the "tractionlock overide" button to release the park pin/brake.
Does your brake function? Actually it is more of a mechanical park pin and the loader cannot move if it is functioning. It is applied by a spring and release by a solinoid and makes a loud click when the soliniod releases it. It can be bypassed with just a hose clamp.
All of the 553, 751, 753,763,853,863 made in the @90 to 98 had the same cab (simular enough to make the door work), the newer ones had the door hinges on the other side in say the 96 to 98 machines.
I think the earlier 742 743 had the same cab to other then the round head lights.
The G series started in 99 and have triangular head lights and they have a door with curved glass, that will really make you cry if you break it $$$$$$$$$$$$$$$$$$$$$$$.
