SpaceCase614
- Joined
- Jan 11, 2013
- Messages
- 22
I had issues where the left side would want to walk forward. i got diagrams from the service manual to adjust neutral and after popping the cab up and taking a look I saw right away what the problem was. The rear cam that is bolted from underneath the aluminum arm is loose. Problem is that it won't tighten, the bolt underneath will thread so far in then start to spin. This lets the cam move around and one of the things that happened yesterday when clearing the driveway was I lost the ability to go forward on the left side. I think it just unthreaded enough and the bolt head jammed in because one I threaded it back down as far as it would go I could push the left stick forward. Sooo .. to fix it I need to take the top plate off which just looks like a heavy spring on one end then it should slide off the two pins, then I can see the aluminum arm. Anyone know if I'll be able to get at the bolt head from there or if I'll have to take the arm off. Also, any ideas how to get that spring off, it seems like it's under a lot of tension.
