763 Not Starting
pyanke
I have a 95' 763 and recently had to replace the fuel shut off timer, I replaced the solenoid to find the timer was bad. It seemed to have solved my problems until I parked the machine for 2 weeks. I go to start it and it beeps and clicks, kind of like the battery is dead. If I keep trying to turn the key on/off there is nothing. I wait awhile and then can reproduce the same beep and clicking, then nothing. I am lost and any ideas or help would be greatly appreciated!!
I assume its a BOSS machine with the beeping, what code is it showing?
The clicks do sound like a flat battery, i assume you tried giving it a charge?
thetool
Dude sounds like a dead battery. Give 'er a jump, and check for about 14.5 V or so when it runs. Charge your battery good and load test it.
Maybe you left your key on last time, but you might have a key-off draw.
Good Luck
P
pyanke
Good Luck
It seems so obvious now. The battery cable was loose in the terminal clamp. I didn't notice it until I was going to swap batteries with my tractor. Thanks for the input!
