753G wheel grind/noise during tight turing
OsceolaCabin
New to skidsteers, purchased this 2001 753G a few months back. Had it out on the first job on Monday and noticed a wheel grind/noise coming from the right side (while sitting in the machine) when under tight turning. It only occurs when doing a zero turn, pushing out on the left lever and right lever in nuetral. I did check the Hydro levels/etc... prior to work on Monday. I did not recheck after, but did not see any leaks.
Administrator
Admin
Did you have the revs up? you need to run the machine at near full throttle or it makes grinding/squealing noises when turning.
Administrator
Admin
No, maybe 3/4 throttle.
3/4 should be enough....
Try near full and see if it works better, if not you may have another problem.
Mine makes a bit of noise when the revs are low, like 1/2 or lower but kick it to 3/4 to full it makes very little noise (that you can hear over the engine that is).
