753 Runs but dont move
trevort
Just bought 753. It runs but do not move. Engine sounds normal. Left side move but right jerks and dont move. Any suggestions on problem? Thanks
Administrator
Admin
So you will spin in a circle using just one side? or does it JUST move with the left steering lever?
It could be your park brake has stuck if you just twitch.
T
trevort
Machine drives when just starts in morning then on right side does not take drive. Appears as if drive goes in and out then machine binds up. Only left wheels are free.
T
trevort
Machine will move in a circle. after a while only left side moves.
skidsteer.ca
Does the engine labor when trying to move the bad side? Does it make any nasty sounds? We need a few more details to try and help
If you put the machine on blocks will it turn the wheels?are they jambing or locking up or do they just have insuficient power to push the machine? reverse is the same?
T
trevort
The engine is perfect. The wheels turn just it does not have sufficient power to push the machine on the right side. machine reverse OK.
