753 pump *hums*
T
Ok, took the return line from the filter to the pump off, plugged the port on the pump. Hooked up a bottle to catch the oil from the hose to the filter, started it and checked the gauge, no pressure. Filled the bottle in about 5 seconds so the restriction isn't in the hose. I then checked the elbow to the pump and its also clear.....
I'm going to pull the pump and motor on the weekend if the weather holds, i need to get this problem sorted out, its driving me crazy! I had a look at the pump i have for my 763 thats currently in pieces and there is a hole from the input shaft to the inlet of the pump. The restriction must be here somewhere or someone replaced the shaft bearings and left the seals on them.... I have no idea what the previous owner could have done.
Anyway, time will tell.
FIXED
The problem was the previous owner changed the gear pump, it was a different brand that didn't have an oil feed hole from the hydrostatic pump through into the inlet of the gear pump. Without the port the pressure built up till the cold weather port opened up at 400 PSI. If that wasn't there the oil filter or oil cooler would have blown. It could have even blown the seals on the hydro pump!
I'm sure people will think I'm MAD but i got the engine and pump out, removed the hydraulic pump and took the plate off. I then drilled a 1/2" hole through and into the inlet side of the pump. This made the pump essentially the same as the one it should have had fitted.
Put it all together and its PERFECT, quiet as a mouse! the valve opens up when you lower the arms quickly which is exactly how it should work.
FYI - Removing the pump and motor as one is MUCH easier than it may seem. I removed the engine/pumps on my own this morning, repaired the pump and with the help of my dad and a mad mate that popped over, we had it back in, plumbed and wired up within an hour! Filled with oil and it came back to life. Its messy as you have to crack hydraulic lines but its not at all difficult, just build a lifting jig.
OldMachinist
FIXED
I'm sure no one here thinks your mad for modifying the pump. What did you have to lose if it didn't work you needed a different pump anyway and I agree that removing the pumps and motor as a unit is the best way to work on them. I'd rather spend the little extra time pulling the whole thing than working in a cramped space and busting knuckles anyday and it lets you do a good cleaning in the engine bay where all that fire hazard gunk likes to gather.
T
My thoughts exactly.
I had a spare pump from my 763 that i could have used if needed. A new pump goes for around 5-600 USD so i wasn't too worried. I should have taken pictures.... But its one of those things i just wanted to get done and hope it worked.
I'm sure some people will think i'm mad drilling holes in a perfectly good pump, but it was required for this purpose. I just don't understand WHY they would have installed a different pump, when it was changed the noise would have started and the work needed to adapt the new pump, crazy!
The good thing is with this problem gave me insight to how the hydraulic system works, i didn't understand it beforehand, i had no idea how the charge pressure was regulated but now its so simple. It actually helps to have problems as it makes you learn more about how things work.
