743B lift intermittent, no tilt
Catmandude
Machine was "creeping" forward from left side. I adjusted the cam and solved that problem. I started it up today and now the bucket left pedal lift I have to forcefully push the pedal back to get it to lift, and the same to lower, it takes a few times to get it to move either way, and right pedal tilt does nothing, but I was able to tilt forward once when lift was raised, will not come back. Hyd. tank is full. Filter, mount and hoses get real hot quickly. I know the filter is due to be replaced, but if it is plugged, wouldn't the bypass valve allow oil flow? Coincidence or did something fail or did the drive cam adjustment affect bucket operation? Thanks for any help.
SkidRoe
Are your auxiliary hydraulics stuck on? Try working the right stick laterally, there is a detent that locks them on that may be engaged.
