743 turning problems
They are quite large, i wonder where they got to..... Almost sounds like someone was in there before you and gave up on the repair.
Got everything together and the left side seems to work really good. On the right side when I go forward it seems to jump forward not smooth like the left!!! I am wondering if there is an air lock in the system or something simple that could be causing this
There could still be air in there, but it usually makes lots of noise, not jumping around.
What are the linkages like? are they all tight and not worn? Jumping is common if the linkages are worn as they slop around and kump when it does so.
Checked out all the linkages and found the cams and blocks to be worn out so i flipped the blocks and bought new cams and she is as good as new. Thanx for all your help Tazza
