Thanks Taryn!! I knew if anyone had done this I would find the answer here in this forum. I will check it out to see what I can find.There is no EASY way, but i have done it. I bought a generic fuel shut down solenoid that i made a bracket that mounts to the 2 bolts that hold the throttle arm plate to the engine. It works well! the 3 wires you need to hook up are ground, power to the key, and one to the starter motor.
I'll do my best to take a pictures of my setup, see how i go!Thanks Taryn!! I knew if anyone had done this I would find the answer here in this forum. I will check it out to see what I can find.
