langoley
- Joined
- Nov 10, 2008
- Messages
- 28
Ok,I have a problem. I lost power/drive on the left side of my 642.I was just pushing some lumber debris when I heared a "pop" and lost all pull on the left side. I have another machine for parts but it is a later serial # machine with the spline motors.The motor came out of the late model machine easily after removing the outer bolts. Now for the prroblem,how do I get the earlier style motors out? I removed the mounting nuts but the pump is still attached to the gear set.After pulling the top covers I see that both sides have a "nut"on the inside of each shaft that is approx.1 3/4",and once I get it out do I have to replace the entire center "gear set" with the motor?
