Hi, i'm running a tushogg mulcher, and i'm having trouble getting the high flow turned on. All of the switches seem to be fine and working i have the jumper plug/wire on, the high flow rocker switch light is on. If i roll thumb wheel forward the drum turns like it should but seem's like it"s running on low flow. If i press the rocker switch from hi flow to low theres no change in speed of the drum. If i roll the thumb switch back you can hear the hydraulics come on but the head will not turn. The head is rated at 31-40 gpm. Thanks for any help.
