Other Brand Skidsteer Forums
New Holland Skidsteer Forum
1985 L785 starting help/service manual help
Reply to thread
Message
<blockquote data-quote="Erik6693" data-source="post: 87269" data-attributes="member: 12415"><p>Thanks again for the info. The culprit was a bad ground off the battery to the chassis. I ended up putting a new battery in which it needed anyways, it wouldn't kick over and I have an auxiliary fuel pump on it and it wasn't running, I happened to move the ground and it kicked on. But not enough start it, I ended up using a jumper cable from the battery to the chassis and it fired right up. So I'll be replacing the ground.</p></blockquote><p></p>
[QUOTE="Erik6693, post: 87269, member: 12415"] Thanks again for the info. The culprit was a bad ground off the battery to the chassis. I ended up putting a new battery in which it needed anyways, it wouldn't kick over and I have an auxiliary fuel pump on it and it wasn't running, I happened to move the ground and it kicked on. But not enough start it, I ended up using a jumper cable from the battery to the chassis and it fired right up. So I'll be replacing the ground. [/QUOTE]
Verification
Post reply
