1845C bucket tilt & arm lift not working
agunn
Hi, I have a Case 1845C that runs okay but seeps hydraulic oil out of just about everything. Recently the bucket tilt and arm lift have been getting a bit weak, and yesterday they died altogether. I've never used the auxilary hydraulics, so not sure if they're working, although when I push the pedals it doesn't seem as if the motor is under any load. Any ideas of what the problem might be?
It could be a few things, stuck relief, stuck aux hydraulics.Can you be sure the aux hydraulics is not engaged?
Des
If its not the aux hyrauliics stuck then you need to check the gear pump on the crank shaft under the radiator i have had to fix coupling & gear pump failures.
