Bandit1047
- Joined
- Jan 13, 2008
- Messages
- 117
Can I put 12 X 16.5 tires with 12 plys and 6000 lb. load rating on a machine that came with 14 X 17.5 tires? WITH AN EXPLINATION PLEASE
THANKS
THANKS
The 14 X17.5 rims are 8 lug 8 Inch bolt pattern with a 6 inch center hole and a 5/8 stud.I think 14x17.5 sounds like 9 series tires and they were 10 lug rims with huge lug holes and over sized lug nuts ( almost like a Budd wheel lug ) , 12x16.5 were 8 lugs
Bandit1047, you have asked a question without providing any of the critical information necessary to answer it.The 14 X17.5 rims are 8 lug 8 Inch bolt pattern with a 6 inch center hole and a 5/8 stud.
I think that is typical of 12 X 16.5 rim. so getting the wheels and tire to fit is not the issue.
Will they support the machine is the question.
My skid steer weighs 10,500 lbs. However, I have an implement that weighs 2,500 lbs. bringing this beast up to 13,000 pounds working weight.I have Airless tires so the load rating is not marked and I think it is inconsequential since I am asking about pneumatic tires, a totally different animal. 14 X 17.5 pneumatic tires are normally rated at 6000 to 8000 lbs.Bandit1047, you have asked a question without providing any of the critical information necessary to answer it.
1. What loader do you have, what does it weigh and what is its rated load capacity?
2. What is the load rating on the tires you currently have?
3. What is the load rating on the tires you are looking at?
The answer to your question has two parts:
1. What will physically fit on your loader.
2. What tires have the load rating to support both the loader and its rated load safely.
Do you know the Rated Operating Capacity (ROC) of your loader?My skid steer weighs 10,500 lbs. However, I have an implement that weighs 2,500 lbs. bringing this beast up to 13,000 pounds working weight.I have Airless tires so the load rating is not marked and I think it is inconsequential since I am asking about pneumatic tires, a totally different animal. 14 X 17.5 pneumatic tires are normally rated at 6000 to 8000 lbs.
I am also considering going to a Military 15 X 19.5 tire and skipping the tracks. These 12 or 14 ply tires can be deflated in soft soil and give great floatation in mud or sand. They have a load rating of 9,800 lbs. my main concern is that they can take the skidding action of this monster. I believe that the aspect ratio of a 14 X 17.5 and a 15 X 19.5 is the same My airless tires are 36 inches high and these tires are 38 inches high, just clearing the lift arms. Any comments would be appreciated.
Are you referring to the old straight bar tread tires or the newer styles?My skid steer weighs 10,500 lbs. However, I have an implement that weighs 2,500 lbs. bringing this beast up to 13,000 pounds working weight.I have Airless tires so the load rating is not marked and I think it is inconsequential since I am asking about pneumatic tires, a totally different animal. 14 X 17.5 pneumatic tires are normally rated at 6000 to 8000 lbs.
what brand skidsteerloader is itAre you referring to the old straight bar tread tires or the newer styles?
I would also be concerned with the strength of the sidewalls on the old straight bar tread tires. They may be cheap, but they don't have much rubber in the sidewalls. In addition, the rubber compound was hard and traction was poor.
Machine: Mustang 2109what brand skidsteerloader is it
I figured it wasn't a Bobcat when you discribed your rims as being 8 lug and not 10 ...... maybe the post should be in the Mustang catagoryMachine: Mustang 2109
10,500 curb weight + 3900 lbs. tipping load divided by 2 = 1,950 + 1/2 of machine weight (5,250lbs.) = 7,200 lb. load carrying capacity per tire needed.
I found 15 X 19.5 tires with a load capacity of 9,700 lbs. at 65 PSI air pressure and they can be deflated to 35 PSI if needed for traction in sand or mud. They drop to a load capacity of 9,000 lbs. at 35 PSI.
These are skid steer tires for monster machines, I just don't know all the ramification of going to this size tire.
At maximum air pressure (85lbs.) they are rated at 10,100 lbs.
ANY INPUT IS GREATLY APPRECIATED!
Thanks in advance for any intelligent comments or suggestions.
Joe
I purposely tried to avoid the make of my machine so that the moderator would not stick it into the Mustang column where it got no responses the last time I asked the question.I figured it wasn't a Bobcat when you discribed your rims as being 8 lug and not 10 ...... maybe the post should be in the Mustang catagory
Joe,Machine: Mustang 2109
Joe
Thanks for your input!Joe,
the specs I found online for your loader state an operating weight of 10,520 lbs, ROC of 3850 lbs and a Tipping Load of 7700.
Which puts the max load on each front tire at 9110 lbs.
That still puts the tires you found in the safe zone.
Another issue you may have is a change in the ground clearance. Check the tire heights on what you have vs the tires you are considering.
Changes in ride height also affect the bucket position when the boom is lowered all the way down against the stops. Ideally, with the boom all the way down, you would want the heel of the bucket to just touch the ground with the floor of the bucket sitting flat.
If the heel is above grade, you have to lower the cutting edge to get down to grade. This downward angle will cause the cutting edge to want to dive into the grade as you are cutting.
If the heel is below grade, you will have to be careful to be on the cut grade when you lower the boom and adjust the bucket angle to get back on grade.
The only other issue I can think of with changing tire sizes can be changes to max travel speed.
