Bobcat Skidsteer Forums
white smoke coming
Reply to thread
Message
<blockquote data-quote="Miker67" data-source="post: 41624" data-attributes="member: 5215"><p>When I said Tazza, I was actually referring to the OP. I was confused, shouldn't be posting on pain killers, lol. Now, you are correct, black smoke like you see from tuned pulling trucks and people that step on it way too hard is unburnt fuel. The point to note is that it is at least partially combusted; however, instances where a given cylinder has zero combustion and the motor still runs will result in gobs of pure white smoke. This most often this is due to extreme low compression, but can also be caused by injector pumps gone wild(very rare though).</p></blockquote><p></p>
[QUOTE="Miker67, post: 41624, member: 5215"] When I said Tazza, I was actually referring to the OP. I was confused, shouldn't be posting on pain killers, lol. Now, you are correct, black smoke like you see from tuned pulling trucks and people that step on it way too hard is unburnt fuel. The point to note is that it is at least partially combusted; however, instances where a given cylinder has zero combustion and the motor still runs will result in gobs of pure white smoke. This most often this is due to extreme low compression, but can also be caused by injector pumps gone wild(very rare though). [/QUOTE]
Verification
Post reply
white smoke coming
