Other Brand Skidsteer Forums
Caterpillar Skidsteer Forum
What size/model cat for general contracting?
Reply to thread
Message
<blockquote data-quote="kroog" data-source="post: 92659" data-attributes="member: 1996"><p>You could talk to your CAT dealer salesman to narrow it down. Will you use if more for Digging or Lift and Carry? The 262C has been a dynamite machine with very few problems. It has a tremendous lift capacity(2700lbs). If you don't need a vertical lift machine, I would check into the 256C, which has the same power train, but radial lift-better for digging. If you could find a C series 1 instead of a C series 2, you will get about 10 extra HP. The advantage of the C over D series is no regen nor DEF. Saving Maintenance and $$. Another option is the 246C. Any of these machines would work great.</p></blockquote><p></p>
[QUOTE="kroog, post: 92659, member: 1996"] You could talk to your CAT dealer salesman to narrow it down. Will you use if more for Digging or Lift and Carry? The 262C has been a dynamite machine with very few problems. It has a tremendous lift capacity(2700lbs). If you don't need a vertical lift machine, I would check into the 256C, which has the same power train, but radial lift-better for digging. If you could find a C series 1 instead of a C series 2, you will get about 10 extra HP. The advantage of the C over D series is no regen nor DEF. Saving Maintenance and $$. Another option is the 246C. Any of these machines would work great. [/QUOTE]
Verification
Post reply
