Bobcat Skidsteer Forums
what is this
Reply to thread
Message
<blockquote data-quote="mike_s_82" data-source="post: 43516" data-attributes="member: 3566"><p>When I did mine, I took the hinge off the cab on one side, then you can lift that side to get the spring on. With the weight of the cab, you can easily compress the spring. It helps to have two people because the cab can swing around with only one hinge on.</p></blockquote><p></p>
[QUOTE="mike_s_82, post: 43516, member: 3566"] When I did mine, I took the hinge off the cab on one side, then you can lift that side to get the spring on. With the weight of the cab, you can easily compress the spring. It helps to have two people because the cab can swing around with only one hinge on. [/QUOTE]
Verification
Post reply
what is this
