TL230 quick hitch issues
saskr
Good day folks. We have a TL230 with power tach for buckets etc. It no longer works. You can hear the engine load when "lock" or "unlock" is hit. Switch over valve under entry step in front of door is energizing. Tried swapping hoses at cylinder , no change. BTW, the low flow icon is always "on" in the display. Any thoughts?
S
saskr
Found it! First turn off "low flow" icon in dash tells you. Then found sensor ring around top aux was bent & locked "on". This makes the machine think you have an attachment installed & locks out quick hitch. When all is working there is a "QH" icon on the display telling you quick hitch is working.
Glad you found it, so simple... but a pain that it took a while
