Bobcat Skidsteer Forums
Bobcat Compact Track Loaders
T250 Low Hydraulic Charge shutdown
Reply to thread
Message
<blockquote data-quote="ChickenHouseMaster" data-source="post: 74983" data-attributes="member: 10737"><p>You'll have one visible case drain on the left side of the machine underneath the cab if your looking from the front. Your other one should be up under the hydraulic tank on the right side of the machine. Check your hydraulic pressure sensor I had one go bad and did the same thing until I replaced it. Should be located up by the cooling fan underneath the cab. Youll see another small hydralic filter and on either side of it should be a sensor plumbed into the line going to that filter with 2 or 3 wires going to it.</p></blockquote><p></p>
[QUOTE="ChickenHouseMaster, post: 74983, member: 10737"] You'll have one visible case drain on the left side of the machine underneath the cab if your looking from the front. Your other one should be up under the hydraulic tank on the right side of the machine. Check your hydraulic pressure sensor I had one go bad and did the same thing until I replaced it. Should be located up by the cooling fan underneath the cab. Youll see another small hydralic filter and on either side of it should be a sensor plumbed into the line going to that filter with 2 or 3 wires going to it. [/QUOTE]
Verification
Post reply
