Bobcat Skidsteer Forums
Bobcat Compact Track Loaders
T190 Hub oil
Reply to thread
Message
<blockquote data-quote="7LBSSMALLIE" data-source="post: 82873" data-attributes="member: 6879"><p>if you got heat and air or both . pull cover off heater core and evap and clean out. air than water, inspect track adjust cyls for grease leak at rod. clean birds nest off turbo. pull and inspect batt top water clean terms. put anti corrosion stuff on same. inspect belts. give idlers and rollers a good look and shake. spring aint no time for down time.</p></blockquote><p></p>
[QUOTE="7LBSSMALLIE, post: 82873, member: 6879"] if you got heat and air or both . pull cover off heater core and evap and clean out. air than water, inspect track adjust cyls for grease leak at rod. clean birds nest off turbo. pull and inspect batt top water clean terms. put anti corrosion stuff on same. inspect belts. give idlers and rollers a good look and shake. spring aint no time for down time. [/QUOTE]
Verification
Post reply
T190 Hub oil
